Default fluid type in XFOIL
Old   July 17, 2013, 09:33
Default Default fluid type in XFOIL
yuan tian
kenya0514 is on a distinguished road
Hello
I encountered a problem when I am trying to do some calculation with XFOIL.
I did some measurements with an airfoil in a wind tunnel. And now, I would like to do some calculations with XFOIL using the same configurations as in the measurements.
Since XFOIL gives CL CD directly, I think it is necessary to know the type of fluid (in order to use the right \rho). How can I check that? Or is it possible to change the fluid type to air?
Maybe I am wrong...Please enlighten me. Thank you very much.
kenya0514 is offline   Reply With Quote
Old   July 18, 2013, 03:17
RDG
onyir is on a distinguished road
When you use XFoil, if defining a viscuous calculation, you have to set the Reynolds number and Mach of the simulation. That's the only way you define your fluid, and it should be enought.
onyir is offline   Reply With Quote
Old   July 18, 2013, 03:37
yuan tian
Thank you for your reply...
I still have some doubts...If the fluid type is only defined this way, how would XFOIL calculate CL CD? Since we need F/(0.5\rho U^2 S) to get CL CD, right?
Or does it calculate those another way?
Thank you
Old   July 19, 2013, 02:07
C
whizkid is on a distinguished road
Thank you
You dont have to know the fluid type. maybe you can check Drela's paper, Section 3. http://web.mit.edu/drela/Public/papers/xfoil_sv.pdf
whizkid is offline   Reply With Quote
Thread Tools
Trackbacks are On
dsmcFoam setup hherbol OpenFOAM Pre-Processing 0 July 14, 2013 17:16
ERCOFTAC Centrifugal Pump with kOmegaSST Model marcelgt87 OpenFOAM Running, Solving & CFD 4 March 13, 2013 11:49
Air Conditioned room groovyBC Sebaj OpenFOAM 7 October 31, 2012 15:16
turbulent jet simulation antonio_ing OpenFOAM Running, Solving & CFD 5 September 16, 2010 02:31
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
