F Difference/F Volume/ F Element
Old   August 19, 1998, 11:11
Default F Difference/F Volume/ F Element
Oliver
Can anyone summarise the difference bewteen the three methods, mentioned above. Also if anyone knowns, where I can obtain information related to the F.V.M, I would appreciate it.
Thanks
Oliver
Old   August 20, 1998, 15:01
Default Re: F Difference/F Volume/ F Element
Ravi Krishnamurthy
Essentially the difference between the three methods is the way the solution is expanded on the finite mesh.
The basis function for the finite diff. method is a Dirac delta function with the solution independent on the neighbourhood mesh.
The Finite vol method has a unit step as the basis function with the solution constant over the mesh volume.
The Finite element basis in general is linear that is the 'hat' function.
Each of the above has a higher degree polynomial for the solution basis. This is altered for each of the above cases when more accuracy is required, like higher order spatial accuracuy by interpolation in F.D/F.V methods and increasing the polynomial fit in the F.E. methos, like quadratic elements.
A good starting point is the general CFD books like the one by Anderson, Tannehill and Pletcher.
Ravi
Old   August 21, 1998, 07:24
Oliver
Thanks for your time.
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 21:14
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
