September 2, 2006, 05:04 |
CFD basics
Hello, i'm trying to understand CFD on basis of finite volume method. At the moment I have few questions.
1. To get temperature and velocity values over the model (fluid), I have to solve both Navier-Stokes (N-S) and Mass-energy (M-E) equations. N-S is needed to get velocity values, A M-E to get temperature values. Am I right or wrong? 2. If i'm right in 1, do those (N-S, M-E) equations are solved separately or together? Thanx for your help |
September 2, 2006, 06:23 |
Re: CFD basics
Dear Pawel,
I suppose by the NS you refer to the momentum equations and by ME to the continuity and energy equations. In FVM, the entire system of equations is a non-linear coupled system for compressible flows. The system gets decoupled in the case of incompressible flows, leaving no equation for pressure update, and hence a pressure correction scheme is introduced. You can read up more details in several books. Regards, Ganesh |
September 2, 2006, 07:31 |
Re: CFD basics
Thanks,
Can you recommend me any information in the Internet? I think I understand general idea of this method, but i cant find the details |
September 2, 2006, 08:17 |
Re: CFD basics
Dear Ganesh,
If i am correct, even for incompressible flows, momentum and mass equations can't be solved 100% independently. Pressure correction scheme is used jointly with momentum and mass conservation equation to get parameters throughout the calculation domain. Regards, Sidd |
September 2, 2006, 08:59 |
Re: CFD basics
September 3, 2006, 03:31 |
Re: CFD basics
Thanks
September 4, 2006, 09:03 |
Re: CFD basics
re cfd basics | rajesh | Main CFD Forum | 2 | July 16, 2007 13:44 |
CFD basics... | rohan | CFX | 1 | January 25, 2006 02:01 |
CFD salary | dan collen | Main CFD Forum | 5 | August 22, 2001 09:56 |
basics in cfd | tonshal | Main CFD Forum | 7 | November 30, 1999 04:04 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 12, 1999 23:27 |
