steady free-surface flow simulation interFoam |
October 8, 2018, 10:21 |
Kahlil Fredrick Cui
Rep Power: 8 |
Hello!
Is it possible to simulate a steady free surface flow in interfoam? The scenario I want to simulate is similar to a gravity-driven fluid flow down an inclined plane, but I only want to model a segment of it where the flow velocity is steady. Could this be done through correct BCs perhaps? I have tried modifying the interfoam code to accommodate cyclic boundaries while being inclined but the velocities quickly rise non-stop (calculated velocities can reach up to 100 m/s for 26 degrees and will continue to increase unless terminated) and abnormally high velocities are observed at the air-water interface. I gladly welcome any ideas. Thank you in advance! |
cyclic boundaries, gravity flow, interfoam |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
free surface simulation | Pit7512 | CFX | 12 | October 23, 2015 11:07 |
interFoam simulation yields inconsistent results for alpha1 surface | Ralinus | OpenFOAM Running, Solving & CFD | 8 | January 13, 2014 08:54 |
Steady flow in steady and unstedy simulation | Kwiaci | FLUENT | 4 | August 29, 2012 12:46 |
Multiphase flow. Dispersed and free surface model | Luis | CFX | 8 | May 29, 2007 18:13 |
