2D Momentum ,invicid,incompressible,Finite volume,
Old   September 9, 2006, 03:28
Default 2D Momentum ,invicid,incompressible,Finite volume,
SAEED MAHLOO
I need a fortran source code that meshed and solved invicid incompressible (Euler) momentum equations around a 2D body. This program use SIMPLE algorithm or SIMPLER algorithm for solving 2 momentum equation(PRESSURE LINKED) with UPWIND scheme . The flow go around a rectangular(tetra angle) shape with infinine velocity in straight direction.the infinite velocity is about 50m/s. I need this code very soon. PLEASE help me!!!!! WITH BEST REGARDS
THANKS A LOT
Old   September 9, 2006, 04:06
Default Re: 2D Momentum ,invicid,incompressible,Finite vol
Bounecer
I'm working too on 2D, incompressible, laminar and viscous flow about airfoil. I'm using finite volumes method and SIMPLER algorithm. I'm working on curvellinear coordinates (structured O-grid generation). If you have an idea about that flow case, i'm ready to share informations.
Thread Tools
Trackbacks are On
how to set periodic boundary conditions Ganesh FLUENT 13 January 22, 2014 05:11
BlockMesh FOAM warning gaottino OpenFOAM Native Meshers: blockMesh 7 July 19, 2010 14:11
On the damBreak4phaseFine cases paean OpenFOAM Running, Solving & CFD 0 November 14, 2008 22:14
Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Native Meshers: blockMesh 10 April 2, 2007 14:00
