biCGSTAB Fortran code, unstructured mesh
Old   September 6, 2006, 10:01
Default biCGSTAB Fortran code, unstructured mesh
Nico
I am looking for a working version of the Conjugate Gradient STABilized solver for unstructured meshes. I can't get mine to work properly.
Thanks
Old   September 6, 2006, 10:14
Default Re: biCGSTAB Fortran code, unstructured mesh
Renato.
There isn't a BiCGSTAB specific for unstructured meshes. BiCGSTAB is a linear solver suited for ***non symmetric*** linear systens. It doesn't matter what kind of grid the linear system come from. Regarding the Fortran routine, it can be easily found at Van der Vorst's site (take a look in http://www.math.uu.nl/people/vorst/software.html)
Regards
Renato.
Old   September 8, 2006, 04:32
Nico
Thank you. Similarly, do any of you have a link for a fortran routine of a preconditionned (or not) conjugate gradient (CG) solver (symmetric matrices).
Regards,
Nicolas
Old   September 12, 2006, 06:14
Márcio
Try netlib.org.
Old   September 12, 2006, 11:12
Renato.
Hi Nico,
I'm sure you can easily find a PCG routine at netlib as Marcio suggested, but the PCG algorithm is so simple that you can easily implement it by yourself in 30 lines of code. In order to make the implemantion even more easy I'd suggest the use of BLAS routines (also found in netlib) to perform basic operations.
Cheers
Renato.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
Design Integration with CFD? John C. Chien Main CFD Forum 19 May 17, 2001 15:56
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
