-   -   suggestion about which path should I follow (http://www.cfd-online.com/Forums/main/121985-suggestion-about-path-should-i-follow.html)
Soumyabrata August 9, 2013 11:21
Dear co-users, I need your suggestion regarding one matter. I can do elementary analysis both in ansys fluent & cfx. I can also write some coding in matlab & C as well. But the problem is that I can't decide on which path should I follow for my research activity in the field of CFD for heat transfer analysis. Though fluent & cfx are easy to use but the problem that I am facing in there, is that I can't customize them,whereas though the flexibility is there if I write my own code in matlab or C but then the discretization of the problem becomes a challenge. So I want your expert advice about which path should I follow. Should I continue with the ready made software (which are very difficult to customize) or should I write my own code. :confused:
Thanks in advance. :)
