September 17, 2006, 08:41 |
convective BC for non-vertical exit
hi,
may i know what's the formula for convective BC when the exit is not vertical, like in an o-grid. when i'm using c-grid, the exit is vertical hence, du/dt+U*du/dx=0. Is it the same for o-grid as well? or should it be du/dt+U*du/dn=0.? Thank you. |
September 18, 2006, 09:59 |
Re: convective BC for non-vertical exit
No, if du/dt+U*du/dx=0 is your governing equation, then this equation is valid everywhere, in the interior domain as well as on all boundaries, regardless of their shape. The other equation, i.e. du/dt+U*du/dn, is not equivalent to that. The difference between a straight vertical and curved boundary is that in the former case the implementation of du/dx is easier. You'll have to think how to express du/dx across the curved boundary, and that will indeed involve du/dn, but it's not equal.
Display Modes | |
back pressure at exit for supersonic flow | BigFrank | FLUENT | 6 | April 24, 2014 15:13 |
Supersonic nozzle exit conditions | Betty | Main CFD Forum | 13 | May 24, 2012 00:26 |
Convective / Conductive Heat Transfer in Hypersonic flows | enigma | Main CFD Forum | 2 | November 1, 2009 22:53 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 20:30 |
convective bc | star | Main CFD Forum | 0 | March 24, 2005 08:35 |
