Opening blockMesh File With VTK
But i'm facing a problem. This below code is of openfoam cavity case which shows geometry. . . this code contains the geometry of Square box. It open's quite fine with PARAVIEW but i want to open it with VTK6.0.0. . . .http://www.vtk.org/Wiki/VTK/Examples/Cxx/IO/ReadOBJ . . . I took the code from the link and add the path of openfoam file and also add the vtkOpeFOAMReader.h . . . .but the output is only empty GUI with green color and no geometry and with no error . . . can it happens ?? if yes then do you know wheres the Problem???
Regards /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.1; vertices ( (0 0 0) (1 0 0) (1 1 0) (0 1 0) (0 0 0.1) (1 0 0.1) (1 1 0.1) (0 1 0.1) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 20 1) simpleGrading (1 1 1) ); edges ( ); boundary ( movingWall { type wall; faces ( (3 7 6 2) ); } fixedWalls { type wall; faces ( (0 4 7 3) (2 6 5 1) (1 5 4 0) ); } frontAndBack { type empty; faces ( (0 3 2 1) (4 5 6 7) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // |
