steady and unsteady
Old   September 10, 2006, 19:36
Default steady and unsteady
superfool
As we know ,the steady flow and unsteady flow is different in the CFD,but the governing equations are the same ,jwhich are named as N-S equations. BUT my question is that :what is the diffence between stead and unsteady ?Friends ,please give me some answer.
Old   September 10, 2006, 20:18
Default Re: steady and unsteady
ag
The equations are not the same. The equations for steady flow are a subset of the equations for unsteady flow, arrived at by dropping the time derivatives of the field quantities. In physical terms most flows are unsteady, and can be represented using a steady flow approximation to varying degrees of success - if the time variations of the field variables are small, then the approximation is good. What kind of answer are you looking for beyond that?
Old   September 10, 2006, 20:39
superfool
i want to know what is the unsteady quantifies ,and what is the steady quantifies, specially ,how to deal with the time term in steady treatment in CFD? because the materials in my hand just some papers and these paper presents same equations of steady and unsteady flows, i make mistakes and confused.
thanks for your answers
Old   September 10, 2006, 21:04
Renato.
You should note that in the steady case du/dt=0, which will arrive what ag explained. In other words, the steady state condition is reached when the solution stops to change in time, so, du/dt vanishes.
Hope it help you
Renato.
Old   September 10, 2006, 22:05
superfool
Thanks,i see.
Old   September 11, 2006, 10:03
Mani
the reason why you see the same equations in some unsteady and steady methods is that you can use (or abuse?) the unsteady equations to get to a steady state. if the flow is such that there exists a steady solution as time goes to infinity, you can run CFD on the unsteady equations until any initial unsteadiness (and error) has died out and the unsteady term, as Renato says, is reduced to an acceptable residual. since you're not interested in the time history, these computations don't have to be accurate in time, i.e. the time steps can be as large as your iteration scheme allows. that's simply one way to get to a steady state.
Old   September 12, 2006, 07:57
diaw
Which 'steady state' are you refering to - Eulerian, or Lagrangian? They are different.
desA
Old   September 12, 2006, 09:14
Mani
I am assuming the Eulerian point of view.
Old   September 19, 2006, 09:49
Brostan
Hi Diaw,
What is the different between Eulerian or Lagrangian steady and unsteady state? Regards
Old   September 20, 2006, 22:45
diaw
In simple terms:
Lagrangian steady => substantial derivative = zero.
Eulerian steady => temporal derivative portion of substantial derivative = zero.
So, if you look at the substantial derivative, you can have cases where the whole term is zero, but the temporal & convective portions are non-zero.
Another way of thinking about things:
Lagrangian steady => observer moving on a fluid particle observes no change in time for the property he is observing.
Eulerian steady => observer fixed in space observes how the flow field changes with time (say a series of time snapshots). If this 'picture' does not change in time => temporal term is zero => Eulerian steady.
Hope that helps...
desA
Unsteady DPM with steady solver elobb FLUENT 4 December 16, 2021 03:54
steady to unsteady wlt_1985 FLUENT 6 December 4, 2010 16:17
Steady needs unsteady. nico Main CFD Forum 0 September 21, 2007 04:50
Turbulent: Steady or Unsteady: confusion prem FLUENT 0 March 30, 2006 10:40
steady or unsteady? (in dpm) winnie FLUENT 1 April 28, 2003 11:30
