September 26, 2006, 17:32 |
multi-fluid flow
I am writing a code for 3D, turbulent, compressible, unsteady flow in a curvilinear domain. I am at the point, where I am trying to add a subroutine that takes into consideration that the flow consists of two fluids at the same phase. I am reading some articles, but still I haven't understood what euler-euler or euler-lagrange approach is. Can you suggest me any good article that explains the situation and the different methods? Do I have to solve 2 times the momentum equations for the 2 fluids? Thank you in advance |
September 27, 2006, 18:19 |
Re: multi-fluid flow
What I mean is if someone can explain me the difference between euler-euler and euler-lagnangian approach and the advantages-disadvantages. Thank you
benchmark: flow over a circular cylinder | goodegg | Main CFD Forum | 12 | January 22, 2013 11:47 |
multi fluid mixture model issue | rystokes | CFX | 3 | August 9, 2009 19:13 |
MR Fluid Flow through microchannels | Sinan | FLUENT | 0 | September 18, 2004 00:03 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
