Reynolds stresses without velocity correlations?
Old   October 1, 2006, 16:23
Default Reynolds stresses without velocity correlations?
Phil
Hi all, I have a quick question about calculating the Reynolds stresses in a URANS code without using the velocity correlations directly!
Notation I'll be using:
ui Instantaneous velocity component
Mean(ui) Time arithmetic average of velocity component
u'i Flucuating component of velocity component
The Reynolds stresses are defined as:
Mean(u'iu'i) = Mean(uiui) - Mean(ui)Mean(ui)
In the closed code I am using I have easy access to the following variables:
Mean(ui)
RMS(ui)
Stddev(ui)
I dont have direct access to the velocity correlations e.g. Mean(uiui).
I can calculate the *normal* Reynolds stresses using the available variables with the following formula:
Mean(u'iu'i) = RMS(ui)RMS(ui) - Mean(ui)Mean(ui)
However, this last formula is not valid for the Reynolds *shear* stresses. For example:
Mean(u'v') = RMS(u)RMS(v) - Mean(u)Mean(v)
, is not valid and does not produce the correct values for Mean(u'v').
Does anyone know if it is even possible to calculate the Reynolds shear stresses if you only have access to Mean(ui), RMS(ui), Stddev(ui) ??
If all else fails I could create a user routine to calculate the shear velocity correlations from first principles but I'd rather use the available pre-prepared variables if that is feasible.
Old   October 2, 2006, 04:29
Default Re: Reynolds stresses without velocity correlation
Pennysworth
I think if you are doing URANS then the Reynolds stresses come directly from whatever turbulence model it is you are using. It is part of the system of equations you are solveing for (i.e. it is already calculated/modleled).
I would think that this is the resolved part of the velocity fluctuation. The unresolved part is what comes from your model. Anyway, I think the following notes might be helpful:
http://www.tfd.chalmers.se/doct/comp...iles/urans.pdf
At leaset you can trust them more than me ;-)
RMS velocity and reynolds stres with fluent gina FLUENT 1 May 20, 2013 04:05
Reynolds Stresses in Cylindrical Coordinates steve Main CFD Forum 0 February 7, 2009 13:38
Eh what happened to my reynolds stresses cfd toy CFX 0 July 3, 2008 15:35
Reynolds number or velocity calc hari FLUENT 0 April 21, 2008 03:29
Velocity Under-relaxation in SIMPLE type methods Matt U. Main CFD Forum 6 July 4, 2005 05:29
