-   -   Gradient calculation (http://www.cfd-online.com/Forums/main/12354-gradient-calculation.html)
Harry October 3, 2006 23:04
To calculate 3-D gradient at centroid of a cell, which neighboring cells should be involved? To explain my question in clarity , I divide the neighboring cells of the considered cell into two groups. one group is the cell which has a common face with the considered cell. one group is the cell which only has a common line/point with the cosidered cell. Should I include both two group for gradiet calculation, Or the first group is enough. I found my code based on unstructured grids just considered the neigbouring cells with common face. Now I want to use gradient for interpolation of value at a arbitry point in a cell. I doubt the existing method of gradient calculation is not good enough.
I would appreciate your idea.
Regards,
Harry
Sunny October 7, 2006 03:02
Re: Gradient calculation
Hi Harry,
I have used the first group for gradient calculation, that is only the neighbors with will my cell shares common faces. Using this gradient value for interpolation, I was able to obtain good results for unstructured grids.
I dont think the value of the gradient should depend on values of cells with common edges or vertices, as you dont have any flux input through these cells.
-Sunny
Sunny October 7, 2006 03:07
Re: Gradient calculation (typo)
....only the neighbors with WHICH my cell shares common faces....
Harry October 7, 2006 04:19
Thanks, Sunny. I orginally want to acquire gas properties (velocity, porosity, pressure) at an arbitary point in a cell using their gradients. I mean gradient is used for interpolation calculation, not for the solution of fluid flow.
The related results are dissapoint as this method has a bad boundedness (some value is beyong physical meaning) and accuracy, especially for big-size cell.
Now I completely give it up.
