Sod shock tube problem with real gas effects
Old   October 17, 2006, 01:22
Default Sod shock tube problem with real gas effects
ganesh
Dear Friends,
I am looking at the Sod shock tube problem, by incorporating real gas effects into my code. My 1-d code has already been validated for the idela gas case. I plan to extend the code to include chemistry also. I would however like to have a suitable test case which involves real gases (and no reactions, to start with) and would be happy if anyone could point out to references in this regard.
Regards and Thanks in advance,
Ganesh
error: uninitialized local variable 't' used MASOUD Fluent UDF and Scheme Programming 5 October 17, 2016 04:24
Parallel User Defined Real Gas Model aeroman FLUENT 4 July 1, 2015 06:09
fprint problem MASOUD Fluent UDF and Scheme Programming 5 October 30, 2011 16:08
Baffle cell problem in shock tube AB Siemens 4 November 15, 2004 08:44
Shock tube problem ger Main CFD Forum 1 September 24, 2003 07:41
