Problem regarding high density ratio(1:1000) in volume of fluid(VOF) method |
September 17, 2013, 05:25 |
jitendra
Rep Power: 12 |
Hi all,
I am using volume of fluid(VOF) method for tracking the interface in multifluid flow. My test case is sloshing of inviscid fluid computational domain is (2*2) square tank top and bottom is wall(no slip boundary condition) and left right is slip boundary condition. For low density ratio i am getting good results but for high density ratio (free surface) interface is distorted completely. Is there any solution for tackle this problem. Thank you in advanced. |
Current density visualisation (PEM fuel cell add-on module) | pchoopanya | FLUENT | 10 | August 21, 2023 14:33 |
The aspect ratio of the volume elements in Finite Volume Method | CharlieTan84 | Main CFD Forum | 3 | August 28, 2012 02:34 |
Comparison: Finite Volume Method vs. Analytic Method | m-fry | Main CFD Forum | 1 | April 20, 2010 14:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
Volume Loss in Level Set Method | Zi-Wei Chiou | Main CFD Forum | 6 | September 19, 2001 09:37 |
