October 6, 2006, 23:10 |
Boundary condition for o-grid
hi ppl,
i need to simulate incompressible flow of a cylinder using an o-grid. Scheme is SIMPLE on structured grid. since the external boundary is a full circle, i wonder how i should impose the BC. i guess if the flow is from left to right, fix inlet u=1,v=0 for left half of circle outlet du/dx,dv/dy=0,p=0 for right half of circle. is this correct? tks in advance |
October 6, 2006, 23:32 |
Re: Boundary condition for o-grid
Dear Joe
I thing since the boundary is far away you should have u=1 and v=0 (instead of the gradients) all over the circle. And the no slip no penetrate conditions on the body its self! P.S. Your B.C.s are logical so i guess they'll work but I thing dirichlect are better! |
October 9, 2006, 08:07 |
I think that you may set your boundary conditions in curvelinear coordinates (ksi,eta) not in cartesian coordinates (x,y), because y're solving your equations in (ksi,eta).
On grid independent solution for pulsatile flow | David | FLUENT | 5 | March 25, 2022 03:33 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
how to set up a wall boundary condition according to calculated wall shear stress? | gameoverli | OpenFOAM Pre-Processing | 1 | May 21, 2009 08:28 |
Spectral Method Boundary condition | Deepak | Main CFD Forum | 1 | February 25, 2004 09:48 |
The Boundary Condition about the Flat Plate | boing | Main CFD Forum | 1 | January 6, 2002 16:53 |
