streamlines
Old   September 2, 1999, 05:50
Default streamlines
ulrich
hi there, i want to calculate streamlines from a given velocity field. where can i get information on the boundary conditions of the laplace equation thank you ulrich
Old   September 2, 1999, 06:26
Default Re: streamlines
NW
At the wall you can set the value of stream function equal zero.
Old   September 2, 1999, 08:47
ulrich
ok, this is evident (thank ypo anyway).
if i have symetry or von neumann boundary conditions, i impose the gradient of the stream function; unfortunately my conjugate gradient algorithm does not converge in these cases.
Old   September 2, 1999, 10:58
Hongjun Li
You don't have to solve the Laplace eq. if you already knew the velocity field (assume 2-D incompressible). You can simply integrete the velocity along the grid line from the solid boundary to get the stream function(sf = int[udy-vdx])at each grid point. This may not be very accurate, but certainly very simple.
Thread Tools
Trackbacks are On
[CFD Post] Surface streamlines not located where needed siw CFX 1 July 7, 2011 19:13
How to get Streamlines to interact.? stephen__white CFX 2 April 12, 2011 17:00
Streamlines under Moving reference frame; Spiral streamline from Tecplot aiqch Tecplot 2 October 30, 2009 00:27
Custom streamlines - only 2 velocity components bernarde STAR-CCM+ 5 August 24, 2009 07:18
STAR-CD, moving grid and streamlines Mohamed GUEROUACHE Main CFD Forum 1 September 13, 1999 13:33
