dynamically allocated memory in C++
Old   November 1, 2006, 19:53
Default dynamically allocated memory in C++
Junseok Kim
I want to convert C program into C++ frame work. Would you help me out the following problem.
I want to use new and delete for the following routinues. Thank you in advance.
If possible, I need a full sample program using the following routines.
double **dmatrix(long nrl, long nrh, long ncl, long nch) {
double **m;
long i, nrow=nrh-nrl+1+NR_END, ncol=nch-ncl+1+NR_END;
m=(double **) malloc((nrow)*sizeof(double*));
m+=NR_END;
m-=nrl;
m[nrl]=(double *) malloc((nrow*ncol)*sizeof(double));
m[nrl]+=NR_END;
m[nrl]-=ncl;
for (i=nrl+1; i<=nrh; i++) m[i]=m[i-1]+ncol;
return m; } void free_dmatrix(double **m, long nrl, long nrh, long ncl, long nch) {
free(m[nrl]+ncl-NR_END);
free(m+nrl-NR_END);
return; }
Old   November 3, 2006, 05:55
Default Re: dynamically allocated memory in C++
Márcio
the changes in your code would be in the allocation / dealocattion commands. The access to the elements in the matrix would be in the same way.
double **m; //unchanged
m = new double*[nrow];
instead of m=(double **) malloc((nrow)*sizeof(double*)), each row would be allocated simmilarly to this:
for(size_t i=0;i < nrow;++i) m[i] = new double[nrow*ncol];
and, to deallocate,
for(size_t i=0;i < nrow;++i) delete[] m[i];
delete[] m;
but, instead of doing this, you should consider using the STL containers, like std::vector or std::valarray, which is best suited for scientific computing.
tip: There's a lot of C++ material on the net, like the book "Thinking in C++", for example, or an online guide on the site www.informit.com, and tons of material in other sites. It's realy worth spending some time searching for it.
I Hope it helps
-Márcio
Old   November 3, 2006, 06:24
chris
I bet you meant
for(size_t i=0;i < nrow;++i) m[i] = new double[ncol * sizeof(double)];
instead of
Old   November 3, 2006, 09:19
Márcio
oops! Thank you.
Old   November 6, 2006, 03:15
O.
For the records: new double[100]; will allocate 100*sizeof(double) bytes in memory (800 bytes on most machines). new double[100*sizeof(double)]; will allocate 100*sizeof(double)*sizeof(double) bytes in memory (6400 bytes on most machines). !!!!
Old   November 13, 2006, 14:22
Angen
Good point O.
Angen
INSUFFICIENT MEMORY ALLOCATED Virag Mishra CFX 2 May 14, 2007 10:02
INSUFFICIENT MEMORY ALLOCATED Error for FSI Cuong CFX 2 November 6, 2006 19:48
CFX CPU time & real time Nick Strantzias CFX 8 July 23, 2006 17:50
INSUFFICIENT MEMORY ALLOCATED Jan CFX 2 July 16, 2003 00:55
INSUFFICIENT MEMORY ALLOCATED xfshi CFX 1 June 19, 2003 18:54
