Inverting speed with Godunov solver
Old   October 6, 2013, 13:06
Default Inverting speed with Godunov solver
Saturn_V is on a distinguished road
Hi all,
I have written a simple Godunov upwind scheme and a HLLC solver to study an astrophysical problem. I tested it with the Sod test and it works smoothly.
Then, I change the initial conditions to the astrophysical ones of my interest and still works fine, until something happens. The problem has spherical symmetry and the gas initially moves with increasing radial distance from the star. As a consequence of gravity, the gas slows down and eventually inverts the motion. That is, the velocity is positive at the beginning and negative after some time. At the inverting point, the program crashes. I suppose that I failed to implement correctly the Godunov flux, writing it only in the positive velocity case. Could you give me a reference where I can find a clear description of this issue?
Thank you very much
Marco
Saturn_V is offline   Reply With Quote
numerical methods, numerical scheme
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM Running, Solving & CFD 17 December 3, 2014 19:41
OpenCL linear solver for OpenFoam 1.7 (alpha) will come out very soon qinmaple OpenFOAM Announcements from Other Sources 4 August 10, 2012 11:00
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM 0 April 4, 2010 18:06
Problem with implicit unsteady solver CCMuser STAR-CCM+ 2 March 3, 2010 11:20
Does it metter to increase RAM for solver speed?? raima Main CFD Forum 1 February 28, 2008 10:47
