October 28, 2006, 03:44 |
How to export gambit model to ICEM
Hi, This is Nirupama. I want to export a 3D model from gambit to ICEM.I have generated a volume for the model. Should i define the boundary conditions in Gambit and then import the model in ICEM. What is the extension to be used while exporting the model to ICEM.
Thanks and Regards Nirupama |
October 28, 2006, 13:06 |
Re: How to export gambit model to ICEM
If you are talking about a geometry - you will want to export the ACIS file (.acs). If you've already generated the mesh, ICEM can simply load the .msh or .cas file.
[ICEM] Export half of the model from ICEM to CFX | enghamed | ANSYS Meshing & Geometry | 3 | July 30, 2010 10:23 |
mesh missing after export in gambit | morteza08 | ANSYS Meshing & Geometry | 1 | July 26, 2010 01:10 |
mesh missing after export in gambit | morteza08 | Main CFD Forum | 0 | July 23, 2010 02:19 |
SketchUp 3D model import to Gambit or Fluent | Steve Johnson | FLUENT | 0 | February 8, 2009 14:21 |
Gambit and parametrized model generation | MN | FLUENT | 0 | October 8, 2003 20:01 |
