October 14, 2013, 16:28 |
Too fine mesh
shohei
This is my first attempt to post a thread here. I am now trying to generate good mesh of bio materials, such as tube. There is 2D mesh on 3D surfaces. I cut a geometry and triangulated around the cut surface in a few times. Then there are too fine mesh around the cutting, and I have to correct it before next step. I want to some how generate rougher mesh from current mesh file(.stl), I mean I want to generate a good new mesh which has similar shape as the current geometry. I tried in some ways, but only result in generating finer mesh. Please teach me if you know the good way to rough mesh. Thank you, shh |
mesh, remeshing, rough |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 11:14 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[Other] Mesh problem/ coarse OK - fine not OK | erichu | OpenFOAM Meshing & Mesh Conversion | 10 | April 10, 2013 12:29 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
