November 9, 2006, 07:03 |
semi-empirical methods
How would you make someone (who has a good understanding of CFD) understand that CFD codes use Semi-empirical methods instead of empirical as for the turbulence model. what are the upsides/downsides ? thanks
November 9, 2006, 09:06 |
Re: semi-empirical methods
What do you call "semi-empirical" and "empirical"? Which turbulent model is purely empirical? Even the most simple models that I am aware of apply some sort of analytical relation (such as mixing-length theory and boundary-layer theory).
On a high level you could argue that all methods (analytical or numerical) based on conservation laws are "semi-empirical", because conservation itself is a fundamental empirical observation. |
November 9, 2006, 09:15 |
hi, well i am using Kameleon fire Ex , which is a safety CFD code... form what i understand empirical methods, based on experimental correlations, are only applicable to simple geometries. KFX uses a semi-empirical method that does not simulate the details of the turbulent motion but only the effect of the turbulence on the mean-flow. the basic concept is to apply the conversation laws for mass momentum and energy averaged over a time scale long compared with that of the turbulent motion. I do use turbulence mixing lenght and turbulence intensity the model is the k-e one.
About multigrid methods | Lionel S. | Main CFD Forum | 10 | April 20, 2007 09:22 |
Implicit, high-order methods for Incompressible NS | Dave Rudolf | Main CFD Forum | 10 | January 29, 2007 10:13 |
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM | kenn | Main CFD Forum | 2 | July 18, 2004 18:28 |
Intl Conf Computational Methods in Fluid Power | Jacek Stecki | Main CFD Forum | 0 | November 10, 2002 05:49 |
Projection methods | ZY Sun | Main CFD Forum | 9 | September 15, 2000 18:00 |
