November 9, 2006, 17:40 |
turbulence intensity at inlet
I am trying to implement k-epsilon model for a complex geometry involving recirculation. Unless I use the inlet turbulence intensity greater than 10% (usually specified as 2-5%), the code is not converging. I wasnt sure, if this would spoil the accuracy of k-epsilon model. Does anybody has any experience with the effect of inlet boundary conditions for k and epsilon.
November 16, 2006, 00:13 |
Re: turbulence intensity at inlet
You should wait till after several hundred times of iteration, it may change to converge. i don't know what is your Reynolds number. if Re is not very high you can set the kinetic energy and turbulence dissipation to 0.1 with k-epsilon model.
Question on Turbulence Intensity | Eric | FLUENT | 1 | March 7, 2012 04:30 |
Turbulence intensity in fully devloped pipe flow - Reference | Shocktrain | Main CFD Forum | 0 | October 14, 2010 06:58 |
High turbulence intensity | wenfengxie | FLUENT | 1 | April 16, 2010 12:00 |
turbulence intensity for skyscraper | antonella grassano | FLUENT | 0 | October 13, 2004 06:50 |
Low Turbulence Intensity Simulation | J. McCarthur | Main CFD Forum | 1 | October 26, 1999 16:17 |
