-   -   gas hold up in bubble (http://www.cfd-online.com/Forums/main/12547-gas-hold-up-bubble.html)
Shelly November 13, 2006 01:28
hi all i need some help regarding bubble column
My gas hold up profile is not getting ::::plz help
I m following the paper of R.krishna(2001)
Geometry: D-0.14m, initial liquid height: 0.9m Superficial gas velocity: 0.019m/s to 0.169 m/s
U Transitional "0.034m/s
Phases "small bubble "4 mm
Large bubble "32mm Water
Below U Transitional only small bubble phase consider
Boundry condition :
Inlet---velocity inlet
Outlet----velocity inlet 2
I startes with course grid : tolal 9000 grids (slightly dence at diffuser and wall)
Different Diffuser for small n large bubble (.00175mm edge ) small bubble diffuser is near to wall Large bubble diffuser is near to center
I calculate inlet velocity ar diffueser =superficial velocity/volume fraction
Outlet velocity is calculate by mass balance as
V(inlet) * fraction*edge(i.e.velocity inlet area) *density = v(oulet) * fraction*edge(i.e.velocity inlet area) *density
Currently I m simulating only for homogenious flow
For this I m using : FLUENT Version: 2d, segregated, eulerian, ske, unsteady (2d, segregated, Eulerian, standard k-epsilon, unsteady) Release: 6.2.16 Quack ,1 st order coupling
