higher grid resolution --> later convergence?
Old   October 31, 2013, 06:35
Default higher grid resolution --> later convergence?
Udo
cfd-noob89 is on a distinguished road
I'm new here and in the CFD-World.
At the moment I'm writing my bachelor's thesis about a fluid flow problem.
My question:
Can anybody give a brief explanation about the fact, that if you calculate the same case for different meshes (for a grid study) it needs more iterations to converge the higher the grid resolution respectively the cell number is?
Thank you very much in advance!
cfd-noob89 is offline   Reply With Quote
Old   October 31, 2013, 07:33
Filippo Maria Denaro
FMDenaro will become famous soon enoughFMDenaro will become famous soon enough
My question:
your question is not very clear... convergence in what? What kind of formulation and solver are you using and for solving what? What about your starting vector?
Just speaking in general, if you solve a linear system with an interative method, the rate of convergence of the method depends on the spectral radius of the iteration matrix. Thus, while changing h, you should check if the spectral radius changes.
FMDenaro is online now   Reply With Quote
Old   October 31, 2013, 09:43
Udo
Excuse me for not expressing clearly and thanks for your answer!
Im not deep into theoretical backgrounds yet. And my advisor at the university is neither.
I have three grids for a combustion furnace with inlet and outlet.
Im using FLUENT with steady-state flow and pressure-based solver (SIMPLE).
The residuals of the coarsest grid are converging earlier than they're doing with finer meshes. What is the reason? Why doest it need not only a longer computing time, but also more iterations till the flow is fully developed?
I'm kindly asking for a quite simply answer, if there is one.
I hope I made myself sufficiently clear enough.
Thank you in advance.
Old   October 31, 2013, 09:46
Simbelmynė's Avatar
Simbelmynė is on a distinguished road
My question:
I don't know about the spektral radius, but if you have a line of people (representing the domain points) and each person can only talk to people next to him/her in order to transmit a message, then it will take more time to transmit that message from one end to the other with increasing number of people, right? If you can talk to the 2 closest people etc., then it will go a little bit faster, but the talking will take more time.
Simbelmynė is offline   Reply With Quote
Old   October 31, 2013, 10:47
Udo
Thanks. That sounds plausible ;-)
Thread Tools
Trackbacks are On
Problem with Grid convergence study dialolema CFX 1 June 14, 2010 18:33
Grid resolution - Segmentation fault George Main CFD Forum 0 September 4, 2007 17:38
Large difference in grid resolution for diff paper Ben Main CFD Forum 16 April 7, 2007 11:45
Higher order discretization on staggered grid Chandra Shekhar Main CFD Forum 9 January 27, 2005 17:31
ratio grid resolution (near wall/center) of dispersed bubbly flow columns using LES Ridwan Setiadi Arrizar Main CFD Forum 1 January 30, 1999 18:43
