Poiseuille flow
Old   November 23, 2006, 13:32
Default Poiseuille flow
Kirikou
It seems to be a very simple question but I'm trying to answer it without results.
While performing the simple case of flow between two plates, my code doesn't work. I found that the problem comes from the boundary conditions. Because I used staggerd grid, I need the value of some fictious value of U and V. I was used to extrapolate but while doing this the continuity equation is not verified. To give you an example :
For U0 = 1 at i=0, i.e. the inflow, this is the two cases I tried :
1st case, I applied the du/dx = 0(u1,j - u-1,j = 0), but obviously d2u/dx2 !=0 (u1,j - 2*u0,j + u-1,j != 0), which is absurd mathematically !!!!!
2nd case, I extrapolate, so d2u/dx2 = 0 but du/dx !=0, it's not absurd but the continuity is not verified on the boundary.
So in the two situation, while computing the pressure boundary condition, we don't obtain dp/dx = 2*(d2u/dy2)/Re, whereas this equation is obtained analyticaly and must be verified.
So where's the problem???? Maybe I miss something but where?????
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Boundary condition and Poiseuille flow simulation Cyp OpenFOAM 6 March 11, 2011 14:53
Spectral methods need help - Poiseuille flow vetnav Main CFD Forum 0 February 5, 2010 13:51
Mass flow and U-Mom flow in CFX Zhihua Xie CFX 0 September 3, 2007 09:49
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
