July 2, 2020, 07:01 |
Turbulence: Inertial Subrange Question
Rep Power: 8 |
hi all,
i'm performing an analysis with my simulation. i want to determine the inertial subrange in my domain. the lower boundary is calculated by: l_DI = 60 * eta = 60 * (kinematicViscosity^3 / epsilon)^0.25 the upper boundary is calculated by: l_EI = 1/6 * k^(3/2) / epsilon source: http://www.bakker.org/dartmouth06/engs150/09-kolm.pdf also same equations can be found in Andersson et al., Computational Fluid Dynamics for Engineers however, when i output the result my lower boundary is always higher than my upper boundary, which can't be correct, bc per definition it should be vice versa. does anybody know whats wrong here? king regards |
Question Regarding Turbulence Numerics | cfdengineer | CFX | 7 | January 27, 2016 16:06 |
General question: turbulence and laminar models | fluentmonkey | Main CFD Forum | 12 | March 17, 2011 14:47 |
Question...Turbulence Intensity & Viscosity ratio | Jay | FLUENT | 1 | October 6, 2005 04:41 |
Inertial diffusive subrange | Xu Zhou | Main CFD Forum | 0 | June 8, 2000 15:42 |
Question about Low Re turbulence modelling. | ghlee | Main CFD Forum | 1 | May 28, 1999 19:29 |
