Reynolds smilarity in CFD
Old   November 26, 2006, 13:00
Default Reynolds smilarity in CFD
Lionel S.
Hi all,
I'm a student specialized in CFD, and I often heard that a big problem for CFD convergence is low viscosity. It seems that programs which adds artificial (numerical or whatever) viscosity has less convergence problems.
In that case, we could simply increase the value of mu (viscosity) and increase another value, as incident velocity (V_inf) or model size (L wing depth for example) in order to keep the right Reynolds Number and converge easily.
Is this technique used in commercial codes, and if not, why ?
Thanks in advance !
LS
Old   November 26, 2006, 17:11
Default Re: Reynolds smilarity in CFD
Lionel S.
Since my first post, I realized that for big Reynolds numbers, the problem will remain numerically stiff. The problem does not come from viscosity but from the Re number.
But if you have comments or other ideas, please make me know.
Old   November 27, 2006, 06:48
Mar
The main problem of CFD code is not low viscosity but stability!
Numerical viscosity is a way to solve the problem (not changing the Re but adding other terms such as jameson's that stabilize the code).
Another way is to use upwind schemes that are "intrinsically stable" and overcome the probelm of adding viscosity.
Mar
Old   November 27, 2006, 16:33
Lionel S.
Hi Mar, thank you for answering
"Numerical viscosity is a way to solve the problem"
Sure, but numerical viscosity makes a poor solution quality, isn't it ?
"Another way is to use upwind schemes that are intrinsically stable "
I don't know any upwind sheme applicable to finite volume methods on coupled approach. Dou you know one ?
Would you have some links to some more theory about these ways to stabilize (finite volume coupled) codes ?
Old   November 28, 2006, 03:10
dhan
I am speaking from my experience in Coupled solvers, Coupled solvers, eddy viscosity (initial turbulence) should be varied to of the order of 10 times of kniematic viscosity, rather than playing with the velocity. For Coupled Solvers I do not have Upwind Scheme available with me. I may be wrong. Please correct me. Cheers.
Old   November 28, 2006, 05:57
Lionel S.
"eddy viscosity (initial turbulence) should be varied to of the order of 10 times of kniematic viscosity"
Does it mean that I should add a "viscous turbulence model" term to Navier-Stokes equations and set it to 10 times the real fluid viscosity to get stability (and a good precision of solution) ?
Old   November 28, 2006, 06:33
dhan
The solver I am using has the parameter Eddy Viscosity with unit m2/sec i.e. Eddy Kinematic Viscosity and requires Initial Turbulence to be specified in the range of 1 to 10 times that of the Kinematic Viscosity of the Real Fluid Kinematic Viscosity. I am not aware which solver you are refering. Very less knowledge about the Fuly Coupled Solvers. Cheers.
Old   November 28, 2006, 16:47
Lionel S.
In fact I'm working on a non commercial solver, and I have some convergence problems for low viscosity. But I will try to make some analysis based on taylor's developements to compute numerical viscosity.
Bye
Thread Tools
Trackbacks are On
CFD Wiki - We Need More Help Jonas Larsson Main CFD Forum 13 September 13, 2005 17:36
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 September 13, 2000 04:48
ASME CFD Symposium, Atlanta, July 2001 Chris R. Kleijn Main CFD Forum 0 August 21, 2000 04:49
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
Which is better to develop in-house CFD code or to buy a available CFD package. Tareq Al-shaalan Main CFD Forum 10 June 12, 1999 23:27
