? Simple CFD problem
Old   August 21, 1998, 06:19
Default ? Simple CFD problem
Davy
Recently, I met a simple flow problem which make us confuse. The problem is as following:
______________
I I
I a I
I_____________I
I I
I b I
I_____________I
In the rectangle vessel, Work fluid (a) is slightly heavier than work fluid (b) ( about one percent and neglect the surface tension ). According to our experience, the bouyancy flow will take place. However, I found there is at all no motion when the stream function-vorticity method to calculate this problem. If we used bossinesq approximation to deal with bouyancy force. If you check the vorticity equation, you will find that the item of the bouyancy force doesn't effect, thus it causes this result. I'd like to know how to accurately define the bouyancy force in this case. Thanks for your help in advance,
Davy
Simple Impinging Fountain problem MarkK CFX 4 February 5, 2011 05:30
CFD Problem Apoorv FLUENT 0 February 13, 2008 15:12
Cooling simple 3D geometry problem Luk FLUENT 4 May 12, 2006 09:47
A simple CFD code for teaching basic CFD? Christoph Lund Main CFD Forum 13 September 14, 2005 04:36
Simple Meshing Problem with Gambit Mario FLUENT 4 April 18, 2003 09:52
