September 7, 1999, 23:48 |
Is this problem well posed?
Hello Everyone:
I am working on a problem and wondering whether the problem I defined is well posed. I am working on a different problem. I will try to illustrate a much simpler problem. I am working on a pure conduction case. Heat Flux ^^^^^^^^^^^^^^^^^^^^^^^^^^^ - - - Aluminum Block - - - - - ^^^^^^^^^^^^^^^^^^^^^^^^^^^ h, Tambient At one end, a constant heat flux is applied. On the other end, a convective boundary condition is applied through heat transfer coefficient, h and the ambient temperature, Tambient. I think by applying a heat flux boundary condition, I am specifying the heat transfer rate at that boundary. Even at the other end, I am specifying the heat transfer rate through the heat transfer coefficeint, h and the ambient temperature, Tambient. There is no reference temperature specified in the computational domain and hence the problem may be ill-posed. on the contrary, if I were to specify a temperature boundary condition instead of the convective boundary condition, the problem will be well posed. What do you all think? Thanks for your feedbacks, Thomas |
September 8, 1999, 06:00 |
Re: Is this problem well posed?
If you can provide an initial condition i.e. the temperature distribution (may be uniform) in the aluminium block, you can run the unsteady heat condution calculations. You will, say, cool the block from the top (given heat flux at the top), this will influence the temperature distribution in the block (heat conduction PLUS accumulation because of finite heat capacity of aluminium). At each time step, the temperature at the bottom of the block you will get as the result of calculations. So the rate of the heat transfer at the bottom (implemented implicitly in your calculations), at each time step, will be known as the bottom temperature of the block, ambient temperature and the heat transfer coefficient are available to the program. If the steady state condition of your problem exists, you'll reach it, after some time, by running unsteady calculations. regards DML
September 8, 1999, 09:52 |
Your boundary conditions are well-posted. Your Tambient will serve as your reference temperature.
September 8, 1999, 14:29 |
Your problem is well posed. Why did you decide that it is ill-posed? Have you some instabillity? Aleksey
September 8, 1999, 14:43 |
yes your problem is well posed because the steady state heat equation (laplace's eqtn) requires two boundary conditions in ach coord direction and these can be specified temp, heat flux (equivalent to temp gradient), or convection BC (which is specified correctly as you have it). whenever you solve steady state heat transfer all you need is one of these BC on every portion of the domain boundary. if you use the time marching approach your choice of initial condition does not affect the steady state temp distribution
September 8, 1999, 14:52 |
Thanks to everyone for your responses. Yes, the problem is well posed. I thought that I saw something strange yesterday to doubt the validity of my boundary conditions. What I saw was physical and I got it confirmed today.
Thanks again, Thomas |
[Other] engineFoam new mesh problem | ayhan515 | OpenFOAM Meshing & Mesh Conversion | 5 | August 10, 2015 08:45 |
UDF compiling problem | Wouter | Fluent UDF and Scheme Programming | 6 | June 6, 2012 04:43 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
