Shock Tube Problem
Old   December 1, 2006, 05:16
Default Shock Tube Problem
Fereeira
Hi my Dears,
I have seen in the literature the following phrase:
"The analytical solution of the shock tube is ..."
But being the Euler equations non-linear one, as one can derive this analytical solution?
Many thaks Ferreira
Old   December 1, 2006, 07:50
Default Re: Shock Tube Problem
ganesh
Dear Fereeira,
Yes, Euler equations are amenable to analytical solutions in certain special cases. In a general scenario, of the flow past a wing or any arbitrary configuration, this is not possible and hence the need for numerical methods. Flow problems governed by Euler equations and which have an anlytical solution are helpful in many ways, such as toi test order of accuracy (in terms of the global error). Two such cases besides the shock tube problem whcihc are govertned by Euler equations and have analytical solutions are the Ringleb flow and Supersonic Vortex case.
Hope this helps
Regards,
Ganesh
Old   December 1, 2006, 15:25
Fereeira
Hi Ganesh,
Thank you very much for you help. But I was thinkg only in the 1D case.
Ferreira
Old   December 7, 2006, 15:22
Default 1D anal solution
TT
I think it's Riemann resolution. Check text books.
Thread Tools
Trackbacks are On
analytical solution of 1D shock tube problem ma Main CFD Forum 10 May 11, 2015 05:20
Shock tube simulation harish FLUENT 5 January 25, 2014 03:20
using ghost fluid method in shock tube problem Amir Main CFD Forum 4 February 24, 2011 11:09
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 1 July 7, 2009 13:44
Need a report on multiplestage shock tube Yoo Main CFD Forum 0 March 24, 2006 12:24
