December 4, 2006, 05:31 |
critical Reynolds number
what is the criticl Reynolds number when water flows through pipe? what is the critical Reynolds number when air flows through pipe? thanks
December 4, 2006, 10:32 |
Re: critical Reynolds number
The critical Re for pipe flow is usually taken as ~ 2300, assuming you are referring to transition to turbulence. This Re is based on pipe diameter and does not depend on the type of fluid.
December 4, 2006, 12:35 |
thanks for ur reply but Reynolds number = ud/kienmatic viscosity.. so Re depends on kinematic viscosity also..... this is my doubt..
December 4, 2006, 13:58 |
Yes, it does - so use the correct kinematic viscosity for the appropriate fluid. The critical Re is still ~2300.
December 4, 2006, 23:26 |
thank u......
Display Modes | |
reynolds number averaging?? | qrie | Main CFD Forum | 0 | June 26, 2010 04:46 |
Low Reynolds Number k-epsilon formulation CFX 10.0 | Chris | CFX | 4 | December 8, 2009 00:51 |
Reynolds Number | Matt | CFX | 0 | February 25, 2009 06:40 |
Critical Reynolds Number | Dipankar Chatterjee | Main CFD Forum | 0 | September 4, 2002 11:01 |
High Reynolds Number Incompressible Flow | Nick Lavery | Main CFD Forum | 3 | February 19, 2002 16:47 |
