Optimize for laminar flow, assume it valid for turbulent flow?
Old   October 21, 2011, 20:15
Default Optimize for laminar flow, assume it valid for turbulent flow?
Chander is on a distinguished road
I want to optimize a design for convective heat transfer and pressure drop.
I have four designs..design 1 ,2,3 and 4.
I want to judge how these designs compare at different inlet Re numbers.
The Re numbers are in laminar region at lowest level and sweep through transition range on the higher side.
I am finding it difficult to get convergence at higher Re both with or without using turbulence models.
However i am able to get converged results at low Re i.e. in the laminar flow regime.
I analyse through CFD and rank the available designs in terms of their performance at low Re i.e. in the laminar flow regime and get a ranking say 2>3>1>4 in terms of their performance for pressure drop and conjugate heat transfer. Now how safe will it be to assume that the same ranking of designs will also hold at higher Re i.e. in the transition and turbulent flow regimes ( and thus avoid CFD analysis at higher Re)?
Chander is offline   Reply With Quote
Old   October 22, 2011, 05:43
cfdnewbie
cfdnewbie is on a distinguished road
I would consider that very dangerous. Turbulent flows can behave significantly different from laminar ones, and extrapolating things like heat or momentum transfer usually goes awfully wrong: that's why Airbus and Boeing are not relying on laminar simulations to build their big birds.
My advice: do the turbulent simulations, maybe you will need to increase your grid resolution, but do not extrapolate laminar results!
cfdnewbie is offline   Reply With Quote
Old   October 24, 2011, 07:43
Thanks cfdnewbie for your advice!
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 12:19
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 21:31
Flow visualization vs. Calculated flow patterns Francisco Saldarriaga Main CFD Forum 1 August 2, 1999 23:18
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 05:18
computation about flow around a yawed cone Tylor Xie Main CFD Forum 0 June 9, 1999 07:33
