December 18, 2006, 06:58 |
High speed multi-phase flow turbulence
What current turbulence models would you recommend to be used with confined VOF multi-phase flow, where the density and velocity differences of the phases are large. Is it possible to use different models for each phase or should I try to find one that gives a good overall description? Best Regards |
About Turbulence Intensity (Pipe flow assimilated) | gRomK13 | Main CFD Forum | 1 | July 10, 2009 03:11 |
High Speed Supersonic Flow Through Pipe | Benjamin Zachariah | Main CFD Forum | 0 | April 19, 2007 10:16 |
About the flow around moving objects with high speed | luckyluke | OpenFOAM Running, Solving & CFD | 2 | February 21, 2006 23:23 |
LES on two phase flow | Li Yang | Main CFD Forum | 0 | May 12, 2004 08:10 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
