December 22, 2006, 12:24 |
deforming meshes
hi,
is there some kind of remeshing after several timesteps when using deforming meshes or is there just deformation, so that one can use this method only for oscillatory movement? does anybody know a good paper where I can read about this? david |
December 25, 2006, 08:39 |
Re: deforming meshes
It seems that transfinite interpolation can be used for deforming meshes. but I am not sure which AIAA paper has detail.
December 26, 2006, 00:12 |
If u are using structured grids, u can check out "Unsteady flow calculations with a multi-block moving mesh algorithm" AIAA-2000-1002. Its arc-based TFI is much faster and higher quality compared to Batina's spring mtd. Hope it helps.
Display Modes | |
Deforming wall problem | alxasli | FLUENT | 3 | January 10, 2011 06:22 |
deforming meshes | joseduartedasilva | FLUENT | 0 | August 10, 2010 18:22 |
Deforming meshes | Etienne.P | FLUENT | 1 | October 26, 2005 04:31 |
IC piston motion - deforming meshes | AMV | FLUENT | 0 | September 16, 2003 13:10 |
Wanted: Examples of Deforming Meshes | Greg Perkins | Main CFD Forum | 3 | June 25, 2001 08:10 |
