December 20, 2013, 08:25 |
Range y plus (wall functions)
faza dzulhimam
Rep Power: 12 |
what range standard for y plus in turbulent flow?
my case is standard wall function with k - epsilon model range Re 7000 - 42000 thanks for help FAZA |
December 20, 2013, 08:42 |
srt
Rep Power: 12 |
If you are using wall function y+>30 sould be safe. If there is severe transition region you may need to use non-equilibrium model. Also if your problem is 2D and it does not require too much computational power you can create your grid finer I mean with y+ ~1 or et least 3-5 by this way you can use enhanced wall function with a good resolution. P.S. I assumed that you are using Fluent.
December 20, 2013, 09:57 |
#3 | |
faza dzulhimam
Rep Power: 12 |
my problem is 3D in tube with length 375mm, in my simulation y+ is too low, how to increase y+ if i use standard wall functions? i used ANSYS FLUENT for my simulation |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 11:55 |
wall functions implementation | besh | OpenFOAM Programming & Development | 0 | January 1, 2013 09:14 |
Are you relying on wall functions? | sek | OpenFOAM | 1 | November 8, 2009 18:27 |
Heat Transfer using Wall Functions | Tristan | CFX | 0 | May 12, 2009 21:01 |
Wall functions | tutlhino | OpenFOAM Pre-Processing | 0 | July 2, 2007 05:04 |
