Convergence to a different maximum
Old   January 13, 2007, 23:43
Default Convergence to a different maximum
Harish
I'm working on a problem of acoustic scattering of a periodic pressure pulse from a cylinder using Linearized Euler equation.The spatial discretization is a higher order central difference and Runga-Kutta is used for time marching.I have a numerical filter to add stability and a buffer zone at domain outlet to absorb the outgoing waves.Since the problem is symmetric I use just half the cylinder with a symmetry condition.
I ran my code on different grid sizes and the results do not converge.Once the results become periodic the acoustic pressure is just a sine wave of the initial time period T.My results,for different grid sizes attain periodicity with different peak amplitudes.On a 500*500 grid the peak amplitude was 3e-5,4.5e-5 on a 600*600 grid and 3.4e-5 on a 700*700 grid.There is no dispersion error.
I need some advice on what could be the reason for the observed oscillations.
Old   January 15, 2007, 18:02
Default Re: Convergence to a different maximum
Mani
What makes you think convergence has to be monotonous? Try 800x800. If you get an amplitude around 4e-5, you're closing in...
Thread Tools
Trackbacks are On
Convergence Centurion2011 FLUENT 33 November 8, 2016 16:08
Force can not converge colopolo CFX 13 October 4, 2011 22:03
early stall, poor convergence, and mesh quality everest CFX 2 May 12, 2010 16:27
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
increasing mesh quality is leading to poor convergence tippo CFX 2 May 5, 2009 10:55
