STAR-CD, moving grid and streamlines
I have a problem with plotting streamlines from a transient file 29 corresponding to a transient and moving grid problem. I want to do a streamlines animation but I can't plot streamlines after storing a particular iteration. If I use the Load 9 command, It loads the last iteration. I use the following commands to plot streamlines EVFILE CONNECT EVLOAD RESET LOAD 9 MVGRID POPT CONT CSCALE,20,auto,standard THIN,0.00 GETV NONE STRE TERM,,,VECT PLME OFF EDGE ON CPLOT This method works well but gives only the streamlines at the last time step. If now I use the STOR command to load the same iteration (the last one) streamlines are not plotted : EVFILE CONNECT EVLOAD RESET TRLOAD 29 MVGRID POPT CONT CSCALE,20,auto,standard THIN,0.00 STOR ITER (the last iteration number) EVLOAD UPTO STORED GETV NONE STRE TERM,,,VECT PLME OFF EDGE ON CPLOT I don't see where is the problem. Can someone help me? is there any additional command or is it an inner problem in star3.05? Thanks for help and time consideration. Mohamed. guerou@isitem.univ-nantes.fr |
Re: STAR-CD, moving grid and streamlines
Maybe you did not save "STRE" to file 29
