AutoCAD Inventor vs. CFX (ICEMCFD)
I'm having issues with putting standard .step files into the ICEMCFD mesher (ver 5.7.1 and 10.0).
Basically, I have an assembly with which I derive the "fluid" part from. That is saved to .stp format and I then import it into the ICEMCFD enviroment. What was a nice fluid block turns out to be just a circle, or a similar geometry minus a few surfaces. I feel that there is something I'm not checking, or some arbitrary value in the tolerance that is causing this. Of note, I can import created parts (parts I sketch/extrude) without much fuss, hence I feel the problem may be with how Inventor turns a derived part into a .stp. Any help would be appreciated. |
Re: AutoCAD Inventor vs. CFX (ICEMCFD)
Try importing the AutoCAD .dwg file.
I gave it a running try but no luck. .dwg's are 2-D or have they gotten fancy enough to go 3-D? I'm trying to import the 3-D structure and Inventor won't allow it (IGES,STEP,DEF, etc.)
I'll see if I can throw it into AutoCAD 2006 (not inventor) to see if I can catch the problem (didn't think of it before). Thanks! |
Thanks for the help. I was able to finally get the geometry to work with a little tweaking of the tolerances and file manipulation.
