OpenFoam under Cygwin
Old   January 18, 2007, 17:08
Default OpenFoam under Cygwin
NeaZen
Is it running like linux version? Same performances, no important bugs?
Old   January 20, 2007, 11:23
Default Re: OpenFoam under Cygwin
john deas
If you want to run openfoam under windows, maybe you should take a look at virtualization. You will loose some performance, but your system will be up and running very quickly, which could be enough for testing openfoam. You can look for vmplayer, and "ubuntu edgy eft appliance" for example.
Old   January 21, 2007, 08:00
Hrvoje Jasak
There is a precompiled version of OpenFOAM for Windows under Cygwin and a lot of details on this subject on the OpenFOAM User Forum. This will run out-of-box and if you really wish to use Windows this is what I recommend.
However, your life will be much easier if you stick to Linux (at least until the Lunix build issues get resolved). I'm hoping we will make some progress with OpenFOAM on both Windows and Mac OS X on the Workshop in Zagreb in June.
Hrv
Old   January 21, 2007, 12:32
rt
Is there any performance leake when it run under cygwin dll? (if what amount, do u have any comparison)
New OpenFOAM Forum Structure jola OpenFOAM 2 October 19, 2011 06:55
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Modified OpenFOAM Forum Structure and New Mailing-List pete Site News & Announcements 0 June 29, 2009 05:56
How can I build OpenFOAM in cygwin joywe OpenFOAM Installation 10 September 12, 2008 09:39
OpenFOAM Cygwin port updated to 13 brooksmoses OpenFOAM Installation 29 November 30, 2006 05:49
