mesh resolution for DNS with high prandtl number |
January 10, 2014, 10:14 |
SAM
Dears
I am doing DNS with high prandtle number fluid (Pr=15). 1- Could someone tell me the best resolution for DNS. 2- For high Pr number I should go finer mesh, Could someone tell me what is the relation between Pr and factor of mesh resolution. Bests |
January 10, 2014, 10:39 |
#2 | |
Filippo Maria Denaro
Rep Power: 71 |
Just consider the Peclet number = Re*Pr in the energy equation as the same way as you consider only the Re number in the momentum |
January 10, 2014, 23:40 |
I think I remember from University that the resolution should be the kolmogorov length.
http://en.wikipedia.org/wiki/Kolmogorov_microscales It is not alway ease to find the right epsilon. You can try to estimate it due to Reynolds number and boundary condition or run a coarse grid simulation with k-e turbulence. How do you want to run a DNS anyway. I remember running some LES-code at University for several weeks on clusters (and DNS can be factors of magnitude more expensive). Anyway, good luck and fun |
Turbulent Prandtl number | Ravenn | FLUENT | 14 | June 20, 2017 11:13 |
ParaView: Number of cells/points in mesh and field don't match | Jaggy_Snake | OpenFOAM Bugs | 2 | March 1, 2017 09:06 |
[snappyHexMesh] non-smooth mesh | Svensson | OpenFOAM Meshing & Mesh Conversion | 11 | January 18, 2012 09:13 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
