Second order Upwind
Old   January 16, 2007, 15:43
Default Second order Upwind
Mike
Could anyone help me find an article about second order upwind. Is it Quick method or something different.
Best
Old   January 16, 2007, 18:15
Default Re: Second order Upwind
Bren
It'sa type of finite differencing stencil. You should be able to learn about it in any finite difference textbook.
The idea is that finite difference stencils originate from Taylor series. By expanding a function, 'f' say, we can develop finite difference approximations to derivatives.
Upstream differencing means that the finite difference operators are calculated by using points that are up-stream.
An example is the first derivative of f with respect to x (where dx is the grid spacing). The derivative at the node 'i' can be written f_x(central)=(1/2)*(f(i+1)-f(i-1))/dx f_x(upstream)=(f(i+1)-f(i))/dx
Other operators are available; the order of the operator comes from the truncation error in the Taylor series.
Hope this is of some help, Bren
Old   January 17, 2007, 08:35
ag
QUICK is one type of higher-order upwind, and refers to the reconstruction used to generate face values of the field variables (although it can also be used on the flux variables directly). Such reconstructions are typically used in conjunction with Riemann type solvers, although you can also find higher order upwind reconstruction used in incompressible solvers. One can also formally develop upwind stencils following Bren's outline. Try googling for higher-order upwind CFD.
Old   January 22, 2007, 03:05
Valdemir G. Ferreira
Dear Mike,
Please, see Adaptative QUICKEST scheme by VG Ferreira et al. in Communications in Numerical Methods in Engineering (In Press).
VGF
Second Order Upwind: Residuals enricokr FLUENT 28 January 2, 2018 17:41
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 12:29
Second order upwind is not UPwind!!! Far CFX 9 May 31, 2011 08:21
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 01:50
Changing LimitedLinear to blend with 2nd order upwind instead of 1st order upwind stevenvanharen OpenFOAM Programming & Development 0 April 11, 2011 05:54
