September 21, 1999, 01:53 |
Commercial CFD Codes
I have no experience with commercial CFD codes. I would be grateful if somebody can tell me briefly about the capabilities of some of these packages. I would be satisfied with some general statements. Thank You |
September 21, 1999, 04:18 |
Re: Commercial CFD Codes
Ciao,
you might have a look at vendors homepages. Links to many of them you find in the list of sponsors for cfd-online. If you have more specific questions you may ask again! Heinz |
September 23, 1999, 22:21 |
maybe you can find what you want at http://www.cd.co.uk
September 24, 1999, 01:32 |
I was more interested to know the opinion of some of the users of these packages. Thanks anyway.
September 28, 1999, 06:04 |
We made a great experience with FLUENT 5 by modelling the radiation heta transfer. FLUENT 5 uses the Discrete-Ordinate-Method (DOM) which permits to modell semi-transparent walls. We used CFX 4 also to do this task, but without the transparent wall, which made all the model much complicated.
September 28, 1999, 19:09 |
Praveen, i think you'll find that the users who know CFD and communicate with their CFD vendors have good experiences using CFD. the ones who don't have bad experiences. also you should know what you want to do and choose the code that can do it best. also some users perticularly academic users don't get the customer support. this tends to make your productivity less because the customer support can help you a lot. i've been told by many on this group that not having customer support leads to them having to write lots of add on code. also you can see by the nuber of people asking questions about commercial codes here that it is important to have good customer service. hop that helps. cheers
September 28, 1999, 19:24 |
I think all the commercial CFD Codes are almost the same. The sam model, the same solution method and so on. The important thing how much you can know it. That need help from the company.
September 30, 1999, 12:07 |
there is a great variety in commercial CFD codes and any investigation into what is available will bear this out. such variations are based on: 1. compressible/incompressible flow solution 2. pressure based/density-time marching 3. discrete formulation ie. FD,FV,FEM,spectral or combination of above 4. coupled/segrigated solver strategy for solution of "physical coupling" 5. linear solver ie. Gauss Sidel, Multigrid, SOR, etc. 6. physical models available ie. Multi-phase, radiation, turbulence, physical and thermodynamic property behaviour, combustion/reaction modelling 7...etc! Lots of permutations and combinations of the above and that is only the solver issues NOT pre and post-processors. Good Luck.................................Duane |
September 30, 1999, 12:18 |
#9 |
Hi, Duane:
I think you just say what the commercial CFD COdes can do. I have used the CFX and FLUENT. All most the commercial CFD codes can do what you mentioned. |
Tired of employers focus on commercial code experience | Steven P. | Lounge | 21 | May 14, 2014 09:43 |
CFD JOBS and Expected Salary.... | Noel Harrison | Main CFD Forum | 11 | November 22, 2000 07:15 |
Customer Services | Patrick Godon | Main CFD Forum | 32 | August 23, 1999 06:55 |
solid kinetic theory | wan xiaotao | Main CFD Forum | 6 | August 10, 1999 18:43 |
modifying commercial codes | Richard Carroni | Main CFD Forum | 1 | October 15, 1998 06:38 |
