tetrahedral meshing Codes
Old   August 22, 1998, 11:32
Default tetrahedral meshing Codes
Heinz Wilkening
Hi:
We have developed our own adaptive CFD-Code for explosion modeling. We use as a input a tetrahedral based unstructured mesh in 3-D and based on triangles in 2-D. In the 2-D I have used EASYMESH and TRIANGEL up to now. These codes are public domain and work well. In the 3-D case I have used GEOMPACK (also public domain), which only works well for simple geometries.
Could anybody recommand a public domain code for tetrahedral meshing on non trivial geometries. The code should also be avalible out the USA.
Thank you very much for your help.
Ciao
Heinz
Old   August 26, 1998, 14:03
Default Re: tetrahedral meshing Codes
Aldo Bonfiglioli
NetGen is a 2/3D mesh generator using linear triangular/tetrahedral elements: http://nathan.numa.uni-linz.ac.at/netgen/usenetgen.html (C++) GRUMMP is another 2/3D mesh generator using linear triangular/tetrahedral elements: http://tetra.mech.ubc.ca/GRUMMP/ (C++)
Tetrahedral vs. Hexahedral Meshing for CFD Andy Bartels Main CFD Forum 16 September 20, 2019 10:06
'Tetrahedral meshing has failed for volume...' Murat FLUENT 5 February 19, 2011 04:22
Anisotropic Tetrahedral Meshing using Gridgen? Turbomachinery Pointwise & Gridgen 2 May 7, 2007 07:13
tetrahedral meshing in square channel Aashutosh Magdum FLUENT 4 May 28, 2005 20:27
Singularity of grid?Volume meshing vs face meshing Ken Main CFD Forum 0 September 4, 2003 11:09
