RCS data
Old   February 1, 2007, 02:10
Default RCS data
Ruben
Hello.
I'm testing my 2D code for solving the Maxwell equations. For doing this, I'm looking for RCS data for a typical test problem: the scattering of a TE/TM wave by a perfect conducting NACA 0012 airfoil for different angles of incidence. I have one paper entitled "A least square finite element method for electromagnetic scattering applications" (J. Wu and B. Jiang, 1996) in which this test is considered but, somebody can provide me the reference data for the NACA 0012 or other typical test in 2D?
Thank you in advance,
Ruben
Old   February 2, 2007, 03:05
Default Re: RCS data
Harish
I would suggest you to browse the NASA report archives.(Most of the reports can be downloaded for free ).You might come across some reference information.
Old   February 2, 2007, 10:20
Ruben
Hi Harish.
In this archive I found more tests cases and references. Thank you very much!
But, do you know any report/web/book in which the RCS is tabulated. I mean, in the papers only the plot (angle/RCS) is given but for a serious comparison (error computation for example) I need the data, not only a figure.
Ruben
Old   February 2, 2007, 10:50
Harish
I'm out of my field here.But one thing which I do for comparison with graphs is extract data points from the graph using digitizer.It works pretty well.
【Help】"Error: Update_Time_Level: invalid data" Chen FLUENT 2 August 24, 2014 07:51
export data at nodes Meenu FLUENT 1 December 30, 2011 01:24
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
CGNS vs Tecplot Data Format LWhitson2 Main CFD Forum 3 July 1, 2011 13:50
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
