January 29, 2014, 12:59 |
Coefficient of Drag for Air and Water
Rep Power: 13 |
Let's say I did a air wind tunnel test on a cylinder and get a drag coefficient for a certain Reynolds number. If I did the same test only by replacing air with water and keep the Reynolds number constant, will I get the same drag coefficient? Thank you very much for your time. kilroy |
January 29, 2014, 13:50 |
Rep Power: 13 |
truffaldino, thank you for your response.
I agree that the pressure effect will be the same. But how about the viscous effects. Water and Air have different viscosity. Will not that make a difference (especially for lower Reynolds numbers)? |
January 29, 2014, 14:35 |
This is whole idea of the reynolds number to express all the coefficients in terms of one dimensionless parameter. The reynolds number is the only parameter entering the dimensionless NS equation, so do not worry about different components of drag: Pressure to viscous drag ratio also depend on Re only.
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
