February 5, 2007, 07:03 |
How to determine which model to use?
How many layers do you normally make for low y+, all y+ double layer and high y+? For low y+ is usually more than 3 layers and Wall y+ should be lower than 1, right? Then 2 layers for double all y+ with wall y+ 1-30 and usually 1 or 2 layers for high y+ with wall y+ 30-50. Am I right?
February 5, 2007, 08:03 |
Re: How to determine which model to use?
How do you usually determine the thickness of the prism layer?
Atomization and Breakup model | xck1986 | OpenFOAM | 4 | May 31, 2014 04:43 |
help for different between les model (subgrid-scale model) | liuyuxuan | FLUENT | 1 | October 2, 2009 15:25 |
Grid resolution for full-scale and down scaled model | gravis | Main CFD Forum | 0 | October 2, 2009 10:27 |
2 stage axial turbine model convergence issues | sherifkadry | CFX | 2 | September 7, 2009 20:51 |
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model | Jonas Larsson | FLUENT | 5 | March 13, 2000 03:27 |
