February 6, 2007, 05:58 |
A question for 'Tom'
Hi Tom,
Can I ask you to refresh your memory on a discussion we had around 1 year ago where we were discussing the possibility of shock waves in low-speed viscous flows. You made a comment something along the lines of (paraphrased): The diffusion eats up the characteristics. In view of my current research, could I ask you to please elaborate in more detail on that point? My work in a 2D field shows that you were correct on that comment. Would you be able to describe the mechanism? I've see a comment regarding solitons, where is was stated that the non-linear wave is prevented from breaking by the effect of the dispersion term. I'd like to try & get a minds-eye view of the physical mechanism that the diffusion uses in the N-S. Thanks so much for your time. desA |
Unanswered question | niklas | OpenFOAM | 2 | July 31, 2013 16:03 |
internal field question - PitzDaily Case | atareen64 | OpenFOAM Running, Solving & CFD | 2 | January 26, 2011 15:26 |
Question about Table applicaiton. | universez | OpenFOAM Running, Solving & CFD | 0 | January 12, 2010 20:31 |
CHANNEL FLOW: a question and a request | Carlos | Main CFD Forum | 4 | August 23, 2002 05:55 |
question | K.L.Huang | Siemens | 1 | March 29, 2000 04:57 |
