wall y-plus problem: unable to manage between 30 to 300..kindly help.. |
February 8, 2014, 02:18 |
maaz ahmad
Rep Power: 14 |
i am pasting the problem link here, below,,, images also attached here...
http://www.cfd-online.com/Forums/mai...-building.html |
February 12, 2014, 10:54 |
Lefteris
Rep Power: 15 |
What turbulence model do you plan to use?
Are you going to use FLUENT (or CFX) for you analysis? If so, Menter suggests to follow a y+=1 strategy and use a y+_insensitive turbulence model. I think that most of their models are like that now but take that with a pinch of salt as I'm not absolutely sure.
Lefteris |
February 13, 2014, 23:41 |
#3 | |
maaz ahmad
Rep Power: 14 |
February 14, 2014, 14:51 |
#4 | |
Lefteris
Rep Power: 15 |
Lefteris |
February 15, 2014, 00:13 |
maaz ahmad
Rep Power: 14 |
actually when i refine the mesh to get values of y+=1, gambit crashes with the error: out of memory..so i cant take that much fine mesh..if you can suggest me anything for this ..please..
February 15, 2014, 21:05 |
Lefteris
Rep Power: 15 |
I don't know if there's going to make much difference but try y+<5 and enhanced wall treatment in Fluent. If you gambit crashes again, go again for y+>30 and standard wall functions.
However, I believe that you should refine your grid generally, not just near the walls.
Lefteris |
February 21, 2014, 05:41 |
maaz ahmad
Rep Power: 14 |
my ske and rng values are showing much difference ...anyone can point out the reason...
Display Modes | |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
problem in using of additional variable in wall velocity | adsladsl | CFX | 10 | May 31, 2015 20:29 |
Heat Flux at wall in a conjugate heat transfer problem | Chander | CFX | 2 | July 9, 2011 23:22 |
Two Sided wall Problem | Mk1987 | ANSYS Meshing & Geometry | 0 | March 26, 2010 14:09 |
moving wall BC problem | Sourabh | Main CFD Forum | 1 | August 8, 2006 08:47 |
