-   -   WENO Code (1D Advection Equation) (http://www.cfd-online.com/Forums/main/13010-weno-code-1d-advection-equation.html)
Carolyn February 19, 2007 17:09
Hi Everyone,
I have been trying to implement simple 5th order WENO scheme for a 1-D advection equation in a instantaneous spill situation ( my background is Groundwater Modeling). Therefore I assume that at t=0, C0=1 at cell 1 and for all other time its 0.
I have problems defining the boundary stencils and hence my code does not converge.. Could anyone help me to debug the code or send some suggestions!!
Carolyn
Fortran Code Below
!================================================= ================== ! Program to solve 1D advection equation using 5th order central WENO scheme ! dc/dt + udc/dx=0 C is the concentration and u is the !velocity ! Boundary Condition C(x,t0)=1 x=x0 and t=t0 ! Its a pule of conc C0 with velocity u !================================================= ==================
PROGRAM WENO1
IMPLICIT NONE
INTEGER I,J,Nmax,IT,ITN_max,IC_FLAG
PARAMETER (Nmax=1001,IC_FLAG=1)
REAL *8 U(Nmax),Phi(Nmax),DCDX(Nmax)
REAL *8 Lx,Dx,CFL,Dt,X0,U0,Tlast
REAL *8 Phi_1(Nmax),Phi_2(Nmax),Phi_3(Nmax)
REAL *8 PL(Nmax)
!=============Input variables====================================== ! OPEN(UNIT=1,FILE='Input.txt') ! READ (1,*) X0,Lx,Tlast,CFL,U0 ! CLOSE(UNIT=1) X0=0 Lx=10 Tlast=5 CFL=0.2 U0=0.8
!================================================= ================== ! Variable Initialization ! !================================================= ==================
Dx = (Lx-X0)/REAL(Nmax-1)
Dt = (Dx*CFL/U0)
!Dt=(Dx)**(5/3);
ITN_max = INT(TLast/Dt)
CALL INITIALIZE(Nmax,X0,Dx,U,U0,Phi)
OPEN(UNIT=2,FILE='Initial_Condition.dat',FORM='for matted')
DO I = 1, Nmax
WRITE(2,*)X0+(I-1)*Dx,Phi(I)
END DO
CLOSE(2)
!================================================= =========== ! Start of Time Loop ! Time Discretization done using 3rd order Runge-Kutta Method !================================================= ===========
WRITE(*,*)ITN_max
DO IT = 1, ITN_max
CALL WENO(Nmax,U,Phi,DCDX,Dx)
DO I = 1, Nmax
Phi_1(I) = Phi(I) + Dt*DCDX(I)
Phi_1(1)=0
END DO
CALL WENO(Nmax,U,Phi_1,DCDX,Dx)
DO I = 1, Nmax
Phi_2(I) = 3./4.*Phi(I) + 1./4.*Phi_1(I)+ 1./4.*Dt*DCDX(I)
Phi_2(1)=0
END DO
CALL WENO(Nmax,U,Phi_2,DCDX,Dx)
DO I = 1, Nmax
Phi_3(I) = 1./3.*Phi(I) + 2./3.*Phi_2(I)+ 2./3.*Dt*DCDX(I)
Phi_3(1)=0
END DO
DO I = 1, Nmax
Phi(I) = Phi_3(I)
END DO
END DO
!============= End of Time Loop============================================== ==========
OPEN(UNIT=3,FILE='SOLUTION.dat',FORM='formatted')
DO I = 1, Nmax
WRITE(3,*)X0+(I-1)*Dx,Phi(I)
END DO
CLOSE(3)
!STOP
END
!================================================= ================== ! Subroutine to Initialize the function ! !================================================= ==================
SUBROUTINE INITIALIZE(Nmax,X0,Dx,U,U0,Phi)
IMPLICIT NONE
INTEGER Nmax, I, IR
REAL *8 U(Nmax),Phi(Nmax),Dx,x,X0,PI, U0
x = X0
DO I = 1, Nmax
U(I) = U0
Phi(I)=0.0
x = x + Dx
END DO
Phi(1)=1
RETURN
END !=================End of subroutine Initialize====================================
!================================================= ================================ ! Subroutine to solve 1st Spatial Derivative using 5th-Order Central WENO Scheme !================================================= ================================
SUBROUTINE WENO(Nmax,U,CW,DCDX,Dx)
IMPLICIT NONE
INTEGER Nmax, I, IL, IR, ILL, IRR
REAL *8 U(Nmax),CW(Nmax),DCDX(Nmax),Dx
REAL *8 ROESPD(NMAX)
REAL *8 EFLX_1(NMAX),EFLX_2(NMAX),EFLX_3(NMAX)
REAL *8 WFLX(NMAX)
REAL *8 EPS,d1,d2,d3,alpha1,alpha2,alpha3
REAL *8 beta1,beta2,beta3,w1,w2,w3,SUM_alpha
REAL *8 a1(8),a2(8)
EPS = 1.0E-6
DO I = 1, Nmax
IL = I -1
ILL = I-2
IR = I + 1
IRR = I + 2
IF (IR.GT.Nmax) IR = IR-Nmax+1
IF (IRR.GT.Nmax) IRR = IRR-Nmax+1
IF (IL.LT.1) IL=IL+Nmax-1
IF (ILL.LT.1) ILL=ILL+Nmax-1
EFLX_1(I) = (1.0/3.0)*CW(I) + (5.0/6.0)*CW(IR)- (1./6.)*CW(IRR)
EFLX_2(I) = (-1.0/6.0)*CW(IL) + (5.0/6.0)*CW(I) +(1.0/3.0)*CW(IR)
EFLX_3(I) = (1.0/3.0)*CW(ILL) - (7.0/6.0)*CW(IL) + (11.0/6.0)*CW(I)
beta1 = (13.0/12.0)*(CW(I)-2.0*CW(IR)+ CW(IRR))**2.0 +(1.0/4.0)*(3.0*CW(I)&
-4.0*CW(IR)+CW(IRR))**2.0
beta2 = (13.0/12.0)*(CW(IL)-2.0*CW(I)+CW(IR))**2.0 +(1.0/4.0)*(CW(IL)-CW(IR))**2
beta3 = (13.0/12.0)*(CW(ILL)-2.0*CW(IL)+ CW(I))**2.0 +(1.0/4.0)*(CW(ILL)&
-4.0*CW(IL)+ 3.0*CW(I))**2.0
d1 = 3.0/10.0
d2 = 3.0/5.0
d3 = 1.0/10.0
alpha1 = d1/(EPS+beta1)**2.0
alpha2 = d2/(EPS+beta2)**2.0
alpha3 = d3/(EPS+beta3)**2.0
SUM_alpha = alpha1 + alpha2 + alpha3
w1 = alpha1/SUM_alpha
w2 = alpha2/SUM_alpha
w3 = alpha3/SUM_alpha
WFLX(I) = w1*EFLX_1(I) + w2*EFLX_2(I) + w3*EFLX_3(I)
END DO
DO I = 1, Nmax
IL = I - 1
IR = I + 1
IF (IR.GT.Nmax) IR=IR-Nmax+1
IF (IRR.GT.Nmax) IRR=IRR-Nmax+1
IF (ILL.LT.1)ILL=ILL+Nmax-1
DCDX(I) = -U(I)*(WFLX(I)-WFLX(IL))/DX
DCDX(Nmax)=0
END DO
!================================================= ============ ! Boundary Stencil Definition ! Since boundary stencil (1,2,3 and Nmax-1,Nmax) not !possible to define using 5 point stencil !================================================= ============
DO I=2,3
IRR=I+2
IR=I+1
DCDX(I)=-U(I)*(CW(I+1)-CW(I))/(DX)
END DO
DO I=Nmax-2,Nmax-1
IL=I-1
ILL=I-2
DCDX(I)=-U(I)*(CW(I)-CW(I-1))/(DX)
END DO
DCDX(Nmax)=0
DCDX(1)= -U(1)*(CW(2)-CW(1))/(DX)
RETURN
END
!=================End of Subroutine WENO========================== ! ! !================================================= ==================
rt February 20, 2007 01:54
Re: WENO Code (1D Advection Equation)
valid code, with eno, venleer, roe methods (not weno, weno is similar with eno), is avalible, if u need give ur email
Carolyn February 20, 2007 02:03
My email is carolyn.msu@gmail.com
Thanks
Carolyn
idee February 20, 2007 05:06
I need it please forward to me:
research2phase@yahoo.com
Your help very much appreciated.
yang, x.h. February 22, 2007 22:49
yangxh@ynao.ac.cn
Thank you.
dusky.he March 10, 2007 04:45
I also need it , could you forward to me? qunwuhe@gmail.com
Thanks
Shiv March 11, 2007 14:21
Could you please forward the code to me too. I am using ENO and it will help me in debuggin my code. My email id is shiv4u@gmail.com Thank you in advance
